Macbook Pro - Is the 2.3ghz worth the extra $250?
Brandon Fraley
41
Bay Area, Ca.
Im ready to pull the trigger on a new laptop and I'm trying to figure if it's a good idea to spend the extra $250 the .1ghz in speed.
Any thoughts?
THANKS! :)
-B
No.
It's less than a 1% performance improvement.
It's also hotter than the 2.2GHz, so I would recommend against it - even if it were free.
If you need more performance than the 2.2GHz MBP 17" , then I imagine that, like me, you'll just get a new MBP when the next model comes out.
Hi Brandon,
I'd spend the extra money on ram and a faster hard drive first before opting for this upgrade.
That said, it's likely to be a higher percentage increase than Alexander describes, as the faster cpu has additional cache as well.
I've got the 2.3.
If you end up with the 2.2 we can do a side by side when we work together next. :-)
Best
Steve
Hi Brandon,
I've got the 2.3.
Best
Steve
Sorry, Stephen is right, its 1.36% faster than the 2.2GHz MBP 17"
http://www.primatelabs.ca/blog/2011/02/macbookpro-benchmarks-early-2011/
And, that's Geekbench, which, like most synthetic benchmarks is biased towards improvements in CPU performance like more or faster cache or memory controller. Cinebench is a better estimate for out work, but I haven't found any Cinebench results for the 2.3GHz 2011 MBP.
The gross clock speed would indicate a max theoretical increase of 4.3%.
The discrepancy is probably down to increased failures in branch prediction.
Sorry for the sloppy number earlier, but I stand by my advice.
I also agree with Stephen and Keith ... more RAM and an SSD will do more for performance than this clock speed bump.
Awesome. Thanks guys :)
-B
