FS: Gen10 HD SD Sync Generator
Gregory Leno
Portland, Oregon
www.bluquill.com
$185.00 - ( reg.$390.00 from B&H if you can get one http://bit.ly/iDzQ7l )
New in Box. Never Used. PM me if interested.
The GEN10 is a cost effective and flexible SD/HD/AES sync generator. The GEN10 features 7 outputs including 2 groups of independently controlled SD/HD sync outputs and 1 AES-11 output. The SD outputs can be switched between Color Black or Color Bars. HD tri-level sync can be switched between 19 different HD formats including all that are in use today. The AES-11 output can be switched between SILENCE and TONE. All outputs are in sync with each-other and are sourced from an accurate master time base.
Features
HD Tri-level sync generation
SD Color Black or Color Bars
Two groups of independently switchable outputs allowssimultaneous HD and SD sync generation
AES-11 output switchable between silence and tone
Multiple outputs can synchronize entire systemswithout requiring a Sync DA
5-18VDC Power
External Dip Switch Configuration
HD Sync
Trilevel
SD Sync
Color Black, 75% Color Bars
AES
AES-11, 48KHz, Silent or 1KHz Tone (-20db FSD)
Accuracy
3 ppm
Formats
525i, 625i
720p23.98/24/25/29.97/30/60
1080i50/59.94/60
1080psf23.98/24/25/29.97/30
1080p23.98/24/25/29.97/30
User Controls
External Dipswitch
Size
5.8” x 3.1” x 1” (147 x 79 x 25 mm)
Power
+5-18VDC, 3 watts
Requires Power Supply (*Not Included, DWP needed)
