Tripod for Epic and other cameras
Andrew McCarrick
38
EHT, New Jersey, USSA
I'm looking for a tripod suggestion for a full Red Epic set-up. The tripod will initially be used for a full Sony F3 rig, then Reds and Arri Alexas.
Hi Andrew,
It depends upon how heavy your setup can become.
I have the OConnor 1030HDs. Its max carrying capacity is 18.6kgs at a height of 6 inches. I went for it as for my wildlife filming I won't go for a heavy rig configuration and the Epic size is fine for it. I am not sure how heavy an Arri Alexa setup can be. If it is heavier than you may need to the OConnor 2065 or even the 2575.
A small write up about my 1030HDS http://www.indiawilds.com/diary/oconnor-1030-hds-fluid-head/
The Vinten tripod 3883-3 supports 45kgs. It is a 2:2:1 design. I would prefer the Sachtler 100 ENG 2CF HD tripod as it is a 2:2:2 design and greater carrying capacity of 95kgs. You may like to check my write up about it here: http://www.indiawilds.com/diary/sachtler-cf-100-eng-hd-2-cf-tripod/
If you are going for OConnor 2065 or 2575 they have 150mm bowl. So you need to either go for a tripod with 150mm bowl or use an adapter.
Happy tripod hunting. :-)
Sabyasachi
O'Connor 2575
Ia am using the Oconnor 1030 HDs and Gitzo 1548 GT Sticks, works great! Even with a fully rigged up Red One or Alexa.
Dear Andrew,
Innocinema is currently running a special on O'Connor tripods!
All O'Connor Tripods
OConnor Ultimate 2575D Fluid Head Package (150mm)
Retail Price: $15,000.00 OUR PRICE: $13,500.00
(Mitchell)
OConnor Ultimate 1030HDS Fluid Head Package
Retail Price: $7,030.00 OUR PRICE: $6,327.0
