Outputing Quicktime Files with Multichannel Audio?
Kenn Michael
For file-based network deliveries in FCP, I could create my timeline with my LoRo and Split Track Dx/Mx audio tracks and output that timeline as a Quicktime with the multichannel audio embedded. Is this doable in Premiere?
What type of track layout do you want in your QT files?
Dave
Basically, as you guys have it now, I can set the number of physical outputs a sequence has at 2, 5.1 and 16. It would be great to add 4, 8 and 12 to that list (maybe even 24). Then in the timeline, I can assign each track to a physical output in the Audio Mixer. When I go to export media (let's say in this case to a QuickTime movie), I would get the option to have each 'physical' output be its own channel in the multichannel QT movie that gets exported. Does that make sense?
I'd use it to, but for mxf, mpeg export. 4 channel output for example. 1&2 Stereo Mix, 3&4 M/E... and so on
Ok great, just wanted to get the exact request.
Dave
