Daniele Mercanti
New member
Hi there,
I'm the DIT on a feature over in London, I think I just bumped onto a bug with REDCINE-X
- REDCINE-X_build_454 - Audio Match function doesn't work with 96.000KHz 24bit audio.
- Also the waveform does not render correctly making manual synching impossible.
Files are coming from a TASCAM recorder. They are .WAV multitrack files.
Application worked fine with audio recorded at 48.000KHz. on a Sound Devices recorder.
Also worked fine when I downsampled the TASCAM 96.000KHz to 48.000KHz.
Anybody else having this issue?
Is there a fix?
And by the way,
does someone has a detailed explanation of the 'Rate Override' feature?
thank you,
any help appreciated.
Daniele M.
Is there a fix?
And by the way,
thank you,
Daniele M.
