How to change back focus for Anamorphic lenses
Esmaeil Neisi
47
Australia : Iran
www.digitalnegative.com.au
Hi There,
I don't know if this been discussed before or not , but according to my experience with adjusting back focus for 2x Elite Anamorphic lenses it seems that they mach the distance marks at efferent back focus, so my question is that
I cant find any back focus adjustment system in Epic pl mount so how i could change the back focus in order to mach the focus mark at the lenses.
Best Regard
Esmaiel Neisi
If you're changing your back focus / FFD to accommodate different lens sets, anamorphic or otherwise, then you have lenses that are not properly collimated.
Sorry Jeff but i recentlly got my one colimated its not related to that some thing elss goes on
The PL mount on the camera should be set within 5 microns (0.005mm) of 52mm FFD. If the mount is properly set and verified, and you have lenses with markings that don't line up, then the *lenses* are not properly collimated or need other service. That's just the way it is, you don't adjust your back focus to accommodate different lens sets or types, unless you are changing lens mounts on the camera and need to fine-tune. PL mount should always be set the same, regardless of which PL mount lenses you are using.
The screw to change the back focus on EPIC is located on the top of the brain, right next to the row of 1/4-20 mount holes near the front of the camera. Like Dan said, it' sin the operations manual.
