Chris Parker
REDuser Sponsor
- Jan 30, 2007
I've heard conflicting reports about the Sonnet QIO. Anyone use it a lot and have an opinion?
Hi,
Just received Qio today and do some testing on my MBP Thunderbolt 17", run on OSX 10.6.7. I installed the Qio 1.0.6, then asked to restart, and resulted that my MBP did not recognise anything as if there is no OSX installed. Tried to re-install the OSX but it still won't boot.
A message "You need to restart your computer. Hold down the Power button until it turns off, then press the Power button again" appeared and after restarting again that message keep appeared. NNNNNOOOOOOOOOOOOO.....!!!!!!!!
This means I have to re-format the MBP and lose everything inside, no? Fully hopeless right now and instructions on User's Guide, the FAQ from the website, and updated emails are all mixed-up and gives different information. Can anyone help? Pleaseeeeeeeee..........
Any kind of answers or experience in this would be greatly appreciated. Thanks heaps, guys.
Do not upgrade to 10.6.8 at this time. If you have Qio 1.0.5 software installed and you upgrade to 10.6.8, or you will no longer be able to boot. Sonnet strongly recommends that you install Qio 1.0.6 software but do not yet upgrade to 10.6.8. If you have installed 10.6.8 prior to installing Qio 1.0.6 software and are not able to boot, you can recover with the following steps.
1) Boot from an Mac OS X external drive or DVD.
2) In the Finder, remove the spaces from the name of your system disk that won't boot. For example, rename Macintosh HD to MacintoshHD. (If your system disk has another name use that name in place of MacintoshHD in the next two steps.)
2) Launch Terminal and type:
sudo rm -r /Volumes/MacintoshHD/System/Library/Extensions/STPCIFamily.kext
3) Type:
sudo touch /Volumes/MacintoshHD/System/Library/Extensions
4) Restart
Your system will now boot. If you are running 10.6.8, you can connect your Qio but it may be only partially functional. Sonnet expects to fully support 10.6.8 by mid-July.
MacPro/10.6.7/Qio 1.0.6
SATA Ports...........Functional
CF Cards..............Functional
SD Reader............Functional
SxS Cards............Functional
P2 Cards..............Functional (32-bit mode only)
Boot/Restart.........Functional
Hot Plug Qio.........Not Supported
MacPro/10.6.8/Qio 1.0.6
SxS Cards.............Must insert SxS card and restart, then SxS cards will be seen. Should be fixed by mid-July
P2 Cards..............Not Functional. Should be fixed by mid-July, but note that Panasonic P2 driver is not 64-bit compatible.
MacPro/10.6.8/Qio 1.0.7 (mid July)
SxS Cards.............Functional
MacBook Pro (non-Thunderbolt)/10.6.7/Qio 1.0.6
Boot/Restart........Functional
Hot Plug Qio........Not Supported
MacBook Pro (non-Thunderbolt)/10.6.8/Qio 1.0.6
SxS Cards............Must insert SxS card and then restart or insert SxS cards and hot plug Qio, then SxS cards will be seen. Should be fixed by mid-July
Hot Plug Qio.......Functional
MacBook Pro (non-Thunderbolt)/10.6.8/Qio 1.0.7 (mid-July)
Hot Plug Qio........Functional
Qio......................Not Functional
MacBook Pro (Thunderbolt)/10.6.8/Qio 1.0.6
Boot/Restart........Not Functional (Requires Apple EFI update. To be determined.)
MacBook Pro (Thunderbolt)/10.6.8/Qio 1.0.7 (mid-July)
Boot/Restart........Not Supported (Requires Apple EFI update. Support to be determined.)
Jordan,
I found the mixed up of what Dewi said...
from the instruction list :
and then on below :
Which one is correct ? if this is a some kind of history of previous version, why they didn't put an explanation ? Just like Red's firmware. If there's a new one, they always put explanation of previous build, so that we know what is the updates.
Can you share, the steps to install the driver based on your experience ?
thanks,
d.p
