FCP 3k, 4k REndering Issue Workflow
Kalechi Noel
New York, New York
Hey,
So i made sure to do do extensive searching on this forum but can't seem to find the "besT" suitable solution.
Problem 1: FCP VS Premiere
Recently got my redMX, and while Premiere CS5 works natively with R3d files, and renders realtime.... I DON'T HAVE THE MASSIVE AMOUNT OF FCP PLUGINS and TRANSITIONS I'VE ACCUMULATED OVER THE YEARS.
Problem 2:
With Final Cut 7 Log and Transfer, I now have ProRes 4444 footage of 2k and 3k resolution. Changing sequence settings to match one, leaves the other one needing rendering. I am editing a music video with a lot of fast cuts, and flashy effects etc. What can I do??
I have Quad Core , 2.8ghz, with 16gb Ram. What's the best workflow I should be looking into??
Thanks in advance.
We need to think it through from the other end: what is you final deliverable? Without knowing that, I can't give you advice on the most convenient workflow.
I would suggest rendering your ProRes out of RedCine-X or similar at whatever your final delivery resolution is. That way you're not working with mixed-resolution footage and dealing with render issues.
I second this. Color and FCP can be quite tricky with 3K – until now.
