Jannard
Red Leader
- Dec 28, 2006
Build 470:
http://red.cachefly.net/redcinex/test/REDCINE-X_build_470_mac64.zip
http://red.cachefly.net/redcinex/test/REDCINE-X_build_470_mac32.zip
http://red.cachefly.net/redcinex/test/REDCINE-X_build_470_win64.zip
http://red.cachefly.net/redcinex/test/REDCINE-X_build_470_win32.zip
Jim
Changes: 454-470
Fixed: rotate and flip framing setting application in the video window for hdr clips when blend is enabled.
Fixed: DRX, Sharpness, and Denoise controls are properly enabled/disabled when rockets are disabled/enabled at runtime
Fixed: HDRx crash when switching between blending and not blending.
Fixed: HDRx in 2d View with 3d clip fixed.
Fixed: misc video player issues issues with frame indexing on the video card.
Fixed: 3d clip crash when one side doesn't return an image.
Fixed: Windows Export crash issue.
Fixed: HDRx Blend enable in viewer crash issue.
Fixed: RMD autosave breaks from using White Balance shortcut key.
Fixed: HDRx blend button disables when you switch between HDRx clips.
Fixed: Slugs appearing as garbage in the viewer.
Colors of some ColorSpace and GammaSpace list items changed.
Additional HDRx info added to Redline output
Eject now works from Video Player
EDL Handling Improvements
ALEs generated from RCX now put the Sync'd External Audio TC into the SoundTC field instead of the source BWF's starting TC.
Quicktime frame rate override feature.
Fix for Viewer 5k Ana from Rocket at 1/8th
Fix for snapshot where fractional frame sizes occurred.
Fix 3d offset range calculation.
Fix frame mismatch in viewer when dropping in a new clip from the bin.
EDL/XML minor improvements.
Fix for properly detecting camera source.
Fixed Debayer setting's dialog not restoring old values if you cancel out.
Fix to show correct clip aspect ratio numerator in clip metadata.
Fix folder history for all export dialog prompts.
Fixed Stereo 3D Meta/Default buttons not showing up in the command stack.
Video Window SAC/SEC meta options now have corresponding tooltips.
Fixed pairing information in RMD's for manual HDR clips.
Fixed absolute and edge timecode calculation in Quicktime exporter.
Fixed undo/redo command descriptions for the curve widget.
Fixed REDLine script checkbox not setting state properly in export format dialog.
Added 3D clip trimming.
Fixed REDLine crashing on exit. More robust error handling if a codec is not found.
Added HDRx Metadata to REDline
Jim
Changes: 454-470
