getting prepared for EPIC
Jon Corcuera
Hi there,
I am just curious to know a couple o f things that maybe the EPIC owners/users can resolve or anyone from the RED team about the second point can jump if they are somewhere in theire list of development:
1. how are you feeding the accesories with the EPIC: Focus pulling, hd converter, sync generator.
2. in the HD-SDI output
a) is showing the image recorded? (if not can it be changed??) i know usually you might want to see what is around but for straight on set dailys i find this will improve quality an eficiency (my 2 mistika Live will enjoy that option for sure)
b) can you switch on/off the marker?, is the output frame rate the same as the TC frame rate base? can it be adjusted? (I mean only for up to 30 fps at this point, even do for the 48 fps 3D projects that could be great to have, I imagine eventualy a solution will be achived).
c) what happens with the output whenever you go hdrx.
3. Are you finding big diferenses in the sensor position for the 3D projects with the EPIC-M, just curious if hand made will make this less acurate.
4. EPIC-Ms in Europe at this point?, curious since we need them for 3D and 2D projects. And for June-July?
Thanks for youre time and happy to see the great footage that is coming out from this cameras :lurk5:
