Kevin Ross
Active member
- May 12, 2011
[FONT=Arial, Helvetica, sans-serif][SIZE=-1]This is a Red Pro 18-85mm T2.9 PL mount zoom lens specifically designed for use with HD cinema cameras such as Red One, Epic, and Scarlet. Features imperial lens measurement, calibrated T stops and focus marks, 142mm OD, 11 inch (28cm) length, 9.9lb (4.5kg) weight. Lens support is reccomended, though not included. Includes front/rear lens caps. This was purchased by my client as a Battle Tested unit directly from Red, which they never used for their project. It has never been used and is thus the same quality as you'd receive directly from Red. Cosmetically it looks same as what one would expect from brand new. It doesn't look "battle tested" at all so much as "like new". Priced at $5,700 + shipping if needed. Contact kevin@broadcastbaron.com
[/SIZE][/FONT]
[/SIZE][/FONT]
