Bulk Meta Data Change
Tim van Dammen
Hey,
I'm wanting to change a large number of clips' color balance. Is there a way to bulk select them and change the color blance on them all at once? Or is there a cut and paste option? I also want to make sure that the change is saved in all the clips' meta data.
Any help would be appreciated.
Cheers
Tim
In the clip preset you can setup what settings to paste with the "Look Setup" button. You can deselect everything and only select kelvin/tint to apply for a preset.
Thanks Deanan.
I can't seem to get it working. I've selected a clip in the viewer and changed the balance. Then I chucked all the clips I wanted to change in the bin. Then I pressed the + button to add a look preset and pressed apply, it seeme dto do something but it didn't change the color balance. I deselected everything in the Look Setup window except Kelvin. What am I doing wrong?
Cheers
Tim
Thanks Deanan.
Cheers
Tim
You had it set to apply to all clips in the bin?
