Redcine-X crashes when importing EDL from Avid Media Composer
I have transcoded 4k red footage to DNXHD 36 by RCXX and edited a feature film with Media Comoser 5. project is dne, I Dplicated the timeline which is 80 minutes and decomposed it inside seperate bin. I created a new timeline with no effects just videos as pull list and saved an file 16 edl. I tried to import the Edl into RCX but it crashes with no messages. I made my edl for less shots. Half of the timeline was imported but after that RCX crashes again doesn't matter howmany clips is being importd s EDL even 10 shots gives me error.
I checked my timeline, there is no overlaping or effects of any kind.
The hard Drive is Raid 0 4 Tb and is half full.
The sytem is I7 980 Extram with 12 GB Ram Running windows 7 ultimate.
Any help is apreciated.
Thank you
Hi Farshid,
What RCX build are you using?
Can you send me your EDL and verbose logs to redcinex at red dot com please?
Thanks,
David
Thanks David,
I am new at this Forum, would you please tell me how to send it to you?
I used both older version and new beta version posted on the support page. I am out of Edit Suit but I can give you the info and EDL tonight.
Thank you very much for your help.
Hi Farshid,
No problem. Inside of RCX you can access the Logs directory from Help menu. Help -> Show Log File...
Inside this directory will be an RCX log file for the current run of RCX.
Make sure Verbose logging is enabled. You can do this from the General tab on the Preferences dialog.
After this is set, import your EDL. And then send me these files :)
David
Thank you David,
Your help is appreciated. I will follow your instructons tonight and will let you know.
How can I send EDL to you? is there an e-mail or message with attachement?
