FS. set of Zeiss - B speeds 25 35 50 85 t1.4
sergio arguello
Buenos Aires,Argentina Los Angeles
www.sergioarguello.com
the lenses are at duclos at the moment...
These lenses are very old and therefore seen there fair use...Duclos advised that they are well worth keeping and are still in good condition.
if you are interested please PM me. Im looking to get 1450 per lens or 5800 for the set.
PM for pictures.
ive recieved an estimate to do the servicing of these lenses from duclos and it came it at 4500 and that included PL and 80mm fronts, as well as the caps. that would make the set about 10,300 which seems reasonable for a 4 lens set of super speeds, yes?
ok let find these lenses a home...the only reason im not keeping and useing these is i just recieved my set of Cooke pancros 18 thru 100mm so
make me any reasonble offer and use them well...im posting the evaluation from duclos and the lenses are there ready for servicing by their new owner...
Zeiss 25mm # 6224590 - Light scratches on front and rear elements (cosmetic only) - Bad haze in rear group and under front element - Iris knob missing - Hardware rusty - Focus and iris lube dry - Focus threads slightly loose - Focus guide keys loose
Zeiss 35mm # 6130907 - Light scratches on front element (cosmetic only) - Oil on iris blades - Iris blades rise at 11 - Focus and iris lube dry - Focus threads loose - Hardware rusty
Zeiss 50mm # 6224340 - Light scratches on front and rear elements (cosmetic only) - Pits on rear element (replacement not available) - Stains in rear optics - Haze in front optics - Oil on iris blades - Focus very stiff - Focus threads slightly loose
Zeiss 85mm # 6224233 - Debris on rear of front element - Lube very dry - Haze in rear optics - Focus threads loose - Iris knob missing - Collimation short
