Albert Frates
I'm selling a Red 18-50 Original Zoom Lens.
The glass is perfect and the gears have NO issues. The only thing wrong with the lens is the tiny red rubber strip on the outside edge of the shade has come off. (Doesn't affect performance or use)
Focal Length Range: 18-50mm
T Stop Range: T3 – T22
Maximum f Stop: f/2.8
Close Focus from Lens Front: 1.73 inches
Length from Front of Lens to Image Plane: 6.16 inches
Minimum Marked Object Distance: 8 inches
Maximum Format Covered: Super 35mm
Diagonal Angle of View for 30mm Image Circle: 75.72 – 31.27 degrees
Iris Scales: Two opposing scales, whole stops marked
Angular Rotation of Iris: 48 degrees
Iris Drive Gear: 116 teeth 0.8 metric module x 0.2 inches wide x 2.91 inches from image plane
Focus Scales: Two opposing scales, footage marked from infinity to MOD
Angular Rotation from Infinity to MOD End-stop: 175 degrees
Angular Rotation Between End-stops: 180 degrees
Focus Drive Gear: 128 teeth, 0.8 metric module x 0.2 inches wide x 4.37 inches from image plane
Zoom Scales: Two opposing zoom scales
Angular Rotation of Zoom Scales: 51 degrees
Zoom Drive Gear: 125 teeth, 0.8 metric module x 0.2 inches wide x 3.59 inches from image plane
Length from Front of Lens to Lens Mount: 4.12 inches
Front Diameter: 4.5 inches
Weight: 1.05 kg / 2.3 lbs.
I'm asking $3000, shoot me your best offer as long as it's reasonable. I accept Paypal or Wire transfer only. The lens is based in Roseville, CA at the moment.
