REDCINE-X Build 449...
Status
Not open for further replies.
Jannard
Red Leader
http://red.cachefly.net/redcinex/eval/REDCINE-X_build_449_mac32.zip
http://red.cachefly.net/redcinex/eval/REDCINE-X_build_449_mac64.zip
http://red.cachefly.net/redcinex/eval/REDCINE-X_build_449_win32.zip
http://red.cachefly.net/redcinex/eval/REDCINE-X_build_449_win64.zip
Firmware:
http://red.cachefly.net/rocket/RED_Rocket_Installer_v1.4.7.zip
Release notes: 416 -> 449:
Scopes added.
Default ISO is 800.
Additional Metadata fields added.
Added additional compression options for EXR.
Added ability to auto cancel export jobs if the output already exists.
HDRx controls for epic. (HDRx viewing is only enabled in "Default 2d" mode. HDRx + 3D viewing is coming.)
Multi-Rocket speed improvement.
Epic source resolutions added to framing controls
RecordFPS added to Redline metadata.
Added Bin/Browser/Export window to the window menu.
In/Out point buttons now highlight respectively if there is an in/out point set on the current clip.
Crop settings are now more intuitive.
Dynamic Cache sizes for better performance on machines with lower amounts of memory.
Framing/Convergence metadata added to burn in options.
3D Rig metadata added to redline printmeta (4) command.
Added updated Avid SDK with a fix for NFS writing.
Added support for auto matching 3d clips using 'D' as the identifier for the primary clip.
Added logging of operating system version and OpenGl version on startup.
Added support for loading of 3D EDL and XML files.
Fixed: DPX header for 16bit dpx to properly represent the ranges used in the dpx files.
Fixed: Undo/Redo for curve control.
Fixed: Use initial clip's in point for timecode on timeline as a single file exports.
Fixed: Playback channels resetting after scrubbing.
Fixed: Audio waveform tool updating when it doesn't need to.
Fixed: Removed M/D buttons from Command History panel.
Fixed: RMD naming issue introduced in 441 and fixed in build 444.
Fixed: Avid INSUFFICIENT_MEDIA error.
Fixed: Crop UI Lock aspect ratio error
Fixed: Crash on browsing.
Fixed: Crash on bad decode.
Fixed: Redline csv missing some commas.
Fixed: SMTPE range with 3d exports.
Fixed: Double click and "Open in Player" in the timeline bin.
Fixed: H-key help window not showing up.
Fixed: Saving of HDRx values to RMD
Fixed: Export timecode issues with in points.
Fixed: Rocket Monitor out: play to end - 1 fixed, play head position fixes, etc
Fixed: UI focus issues with Rocket Setup Dialog.
Jim
Status
