Hi shashbugu,
I agree, AE could definitely benefit from better color correcting tools. If you could be more detailed about the type of color correcting tool that would be useful to you that would be helpful. This is something that is on our plate every cycle and we weigh it against other features.
A little secret, if you dynamic link a ppro project that has a three way color corrector in it, and bring it into AE, the effect will in fact show up, however it will not have any pretty Custom UI (just controls for each parameter). Would it be sufficient to simply upgrade this effect with better custom UI, or were you looking for something different?
Mark,
Why do you say AE on mac is broken? Please elaborate if you are having a problem. Hopefully CS5 should fix your reliability issues. With 64bit, expect less out of memory issues; the limits for out of memory issues to much much higher, as AE can now use all of your system ram (instead of just 2GB limit imposed by a 32bit application).
Thanks for the feedback, it is always welcome,
Amir
Adobe After Effects Developer
Hi Amir,
For working on 4K Red footage with optimum performance on CS5 and taking advantage of Mercury, what minimum hardware specs (ex: CPU, RAM, storage size / throughput and type (SSD or is 7200rpm esata drives ok?) should we be using aside from the Nvidia GPU?
Also, does Mercury work equally well with the Mac Platform, or am I better off upgrading PC hardware...
Many thanks.
