I did a some tests today and here is what I found with my Sekonic meter.
I have not calibrated my meter to the RED MX and am using the factory defaults on the light meter.
To get accurate middle grey readings on the RED MX camera - I am using the spot meter option on the RED camera as well as my Sekonic 758 cine.
I am having to put my ISO on the Sekonic at the following ratings in order to get to brightness 50 on the RED MX spot meter. The camera set on shutter speed 180, 4K 2:1, Redcode 36, most recent build.
Under kitchen flourescent lighting at 3600K with green tinge. Camera WB 3200K.
ISO 800 on MX - ISO 400 on Sekonic.
ISO 500 on MX - ISO 250 on Sekonic.
ISO 320 on MX - between ISO 125 and ISO 160 on Sekonic.
Under incandescent lighting at 2500L. Camera WB 3200K.
Iso 800 on MX - ISO 320 on Sekonic.
ISO 500 on MX - Between ISO 250 and ISO 200 on the Sekonic.
ISO 320 on MX - ISO 125 on Sekonic.
Why is there so much variation between the color temperatures?
Also, something very interesting. Under daylight 5600K camera wb to 5600K. I found a red towel on the ground to be consistently darker than what my meter would give me as a readout. It would be about half a stop darker than what my Sekonic would give me. Does the Red camera absorb less red or does it render red objects less bright? The other colors (non red) were exposed normally.
