- Banned
- #1
albert rudnicki
Banned
I am considering to get a set of 5 ultraprimes.
What are the most common focal lengths used on the 3d rigs?
Thanks!
Thanks!
Thank you David and Ketch.
I should be more specific in my question.
I am ordering a set of 5 lenses (ultraprimes) for my personal use (mostly 2d), but also having in mind to use them on other 3d rigs.
Out of two set I am getting a quote for, what is the focal length that is mostly used on 3d sets today (ultrprimes)
16mm
24mm
32mm
50mm
85mm
or
16mm
28mm
40mm
65mm
85mm
I want to stay compatible with preexisting most common setups.
As the wait time is long and I have everything in place, I need to make a decision fast.
Thank you again for help.
Albert
If I was to choose, I would start as wide as I could, but some Mirror Boxes have limitation on how wide you can go.
So far on ATOM, with Pedro and Tonaci, we have seen the 17mm to be right were it is at.
i wouldn't assume your sets will match with other sets...
you could easily end up buying UPs that are very unususal in terms of specific focal lenght or focus scales.(there are obvously other factors which should be considered when matching lenses)..
If you can specify middle letter focus scales that might help a little but definitly don't assume.
good luck
Michael
Michael
Do you say they have to be factory matched in order to work well on the 3d rigs?
I think it depends on the project whether they "have" to be matched but any variation makes things more difficult in 3d. From a post in another thread about one of the 3d majors in production it spoke of having their lens matched by the tech at the rental house so it appears you can adjust them to match sufficiently but probably not feasible for random rentals. Can I offer an alternative? I can probably get you 2 sets of illuminaS35s for less than a set of ultras and they are very modern new design, Schott glass, lighter, and smaller which is significant with mirror rigs AND they are T1.3! Contact me off list for more info.
We will be testing these this week on ketch's Epic-M.
Actually the choice is not that of the DP alone, as it is the Stereographer that must have a said, as DP's might not have the
knowledge of what effect will be achieved by a said lens.
In 3D, the wider Focal, creates deeper and a more exagerated 3D effect, so it is not just a matter of field of view as in standard
monoscopic 2D, personally I would never allow the DPO to make that decision, that would be my decision as the Director, after
consulting with the Stereographer, which in this case that would also be me, he he...![]()
