Carsten Fenstermacher
- Nov 26, 2008
The basic idea is that when you want to reduce the number of colors you are doing dimensionality reduction, in this case to a single dimension, which actually means that you are projecting colors along a certain direction in linear terminology. In the color space representation the luminance is just a vector - pointing in a certain fixed direction. Similarly, CIE lightness is also a "vector" if you allow non-linear coordinates in the color space. There are infinitely many directions to pick. I picked a "middle ground" direction that gives importance to color saturation.
Sincerely,
Joofa
Your explanation is very obtuse.
The alternate image has had it's black point, white point, and contrast so it's no longer a conversion comparison. Luminance also has the same adjustments it appears.
I got almost the same image as alternate in photoshop by amplifying the CMY in the B&W conv and adjusting the blackpoint.
