Nir Shelter
- Jan 27, 2008
- Age
- 47
- Sydney Australia
- www.datashelter.com.au
In preparation for Redstations/SSD I want to tailor my inputs to fit E-Sata.
Am currently using an E-Sata connection Raid 1 box by Stardom with my MBP through an E-Sata to express card34 adapter great throughput and very reliable.
I connect the Reddrive via FW800 (no bus power FW cable) but soon enough Redstations will connect with E-Sata. I also have a bunch of client HDD that have an E-Sata connection that I rent to clients.
So I want to get an E-Sata hub that will allow all drives sending and receiving to connect via E-Sata. Does any one have experience with an E-Sata hub they can recommend?
Another alternative would be to get a Sohotank ST5610 which is a port multiplier. It can connect via E-Sata and give access to 4 independent drives:
http://www.stardom.com.tw/sohotank_spec.html
Then at the end of the day you can pop one of the drives downloaded to into an iTank enclosure, as they use the same bracket, to deliver to the client:
http://www.stardom.com.tw/itank_feature.html
What are other solutions are people looking at?
Nir.
Nir.
