Lewis-M Soucy
- Mar 21, 2007
- Age
- 58
- Paris
- www.lewis.pro
This one comes so often, thought I'd post this:
To achieve a tone and quality that was true to the story as well as reflected the period in which it is set, Spielberg once again collaborated with cinematographer Janusz Kamiński, saying:
"Early on, we both knew that we did not want this to look like a Technicolor extravaganza about World War II, but more like color newsreel footage from the 1940s, which is very desaturated and low-tech."
Kamiński had the protective coating stripped from the camera lenses, making them closer to those used in the 1940s. He explains that "without the protective coating, the light goes in and starts bouncing around, which makes it slightly more diffused and a bit softer without being out of focus."
The cinematographer completed the overall effect by putting the negative through bleach bypass, a process that reduces brightness and color saturation.
The shutter timing was set to 90 or 45 degrees for many of the battle sequences, as opposed to the standard of 180 degree timing. Kamiński clarifies, "In this way, we attained a certain staccato in the actors' movements and a certain crispness in the explosions, which makes them slightly more realistic."
