Dustin Brown
Active member
- Jan 20, 2008
I too am glad to see the respectful and genuinely helpful responses. It's too easy on these type of forums to put someone down and happens too often.
I don't think so. There's no problem in starting with a DSLR or prosumer camera. You'll actually learn a lot more by using a better, more professional piece of equipment. You can learn very little from a handycam that often times has little to no manual controls. It's too easy to learn bad technique. Better to start with an HDSLR that can actually use interchangeable lenses and one can learn about white balance, iris, DOF, and other manual controls.
The path of cinematography should start at a a Best Buy handy cam.
