Jannard
Red Leader
- Dec 28, 2006
For now, we are going to put eHDR on hold. As a reminder, eHDR™ is the one that does all the processing for you in camera. You select a number (that represents stops of highlight protection) and the camera does the rest.
The more we have used eHDR, the more we can see why having full control over the combining process makes more sense... which is what you have with HDRx.
HDRx™ uses two tracks, one "normal" exposure and one "under" for the highlight protection. This gives you several options.
1. Combine the two frames with the ability to use a slider to control how much of each you choose to use. This results in "Magic Motion".
2. Combine the two frames with help from The Foundry. Same flexibility but the results are "MNMB" (more normal motion blur). There are a few instances when this is the better solution... like dancing flames of a fire.
3. Reference the "under" for motion tracking... then combine (or ignore).
The overall flexibility of HDRx is just too seductive to ignore. It is like shooting RAW was a JPEG. One is infinitely flexible and one is "baked in". One is "pro" and one is not.
For now, we are going with infinitely flexible. That may change down the road... as with all things RED.
Parting shot... EPIC doesn't need an HDR for most situations. The DR and new color science makes this camera an incredible tool just as it is. But it is nice to know that HDRx is there when you reach for it.
Jim
Jim
