Julio Quintana
- Apr 25, 2007
- Austin, TX
- www.juliomquintana.com
This was exactly what we needed. Thanks guys.
Julio
Julio
Agree...
Jim
Thought you might.... :001_cool:
Actually, these new compression options are a lot more significant than many here would probably think. In the television world, efficiency is key. That means quick backups, ease of transport, ease of processing, and ease of data recovery for post production. That's where the original Redcode variants (28, and later, 36) really shine, as they allow for surprisingly small files with little to no downside in terms of grading or matte extraction capabilities for an HD resolution finishing path. They can be stored, copied, and, yes, sent over high speed data networks (including Internet based transports) with relative ease and in a reasonable time frame, allowing, for instance, last minute pickups on a show shot in Toronto to be sent for both editorial and conform in Los Angeles without a physical delivery and its attendant delays when necessary (gee, I wonder what show I'm thinking of here? Hmmmmm....). But in the feature world, one of the knocks on Red has always been the rather significant compression ratios, which at least in theory cause a bit of loss in high frequency detail as well as unnatural noise, particularly in the blue channel, that in turn can cause some issues with matte extractions for large screen presentation. Personally, I've always felt that these problems were largely addressed with the new sensor design, but I have seen some evidence of these issues, albeit very, very rare. However, introducing the lower compression ratios more directly addresses that objection, and having both allows for tailored work paths for different projects, and more directly differentiates and answers the needs of television and features based on each one's reality. It's no longer a good camera for television but a questionable one for big features, or vice versa. It's both in one package.
Now, all you need is that ProRes/DNxHD recording module and you'll be all set....(there's that damn television mindset again.....)
But then you have the option to record 4k 16:9 and still get a bit less compresssion, right?
Maybe even 4kHD...
I have found RC 42 to show some worthy improvement and when using it in 4KHD mode it is perfect for me. Yes, some additional data to backup but some nicer quality. And 4.5k mode at RC42 is beautiful. So, in general I agree with Mike that if the quality of RC 28 and RC 36 is good enough, then shows might as well stick with it. However if data rate is not the issue and quality is a bigger factor, opt for RC42. Jim, thanks for giving us the options!
Which begs the question, do you see future RED SSDs on the horizon that will accommodate the higher frame rates and lower compression?Mike... further to your perspective, when you shoot high frame rates to an SSD the compression numbers need to rise (data rate thing). Some will complain that they are forced to shoot 10:1 (or whatever)... when that has proven to give a great image for the past 3 years.
Jim
Actually, I'm interested in the other end of the performance spectrum. Have RED considered selling the "seconds" - the SSD's that don't make the current specs, but would be good enough for, say, 8:1, 120fps, 3K 2:1, no HDRx™ (i.e. almost any use on Scarlet)? I know nothing more about chip fabrication than I've read on REDUSER, but it would seem that RED is taking the cream of the crop for it's SSD's, but there would be plenty of "lighter cream" available from the fabricator for Scarlet owners. I'm assuming these would be made available a a substantial discount to the current SSD's. Even half the speed of what I spec'd above would work for me, and I suspect a lot of Scarlet owners.
Good question. We reject all that don't pass. I'm not sure we have the bandwidth to sell two different qualities with special WARNING markings. Will consider but probably unlikely.
Jim
Jim, what about cheap, Red1 and Scarlet only media? Surely most of your rejects could handle RC42 on Red1 easily
We already have cheap media for the R1 and Scarlet... CF cards. My bet is you'll be able to pick up a ton of them cheap as people migrate to SSD. I'm really not big on two grades of SSD but will consider it. It is a marketing nightmare.
"So... which SSDs did you bring?"
"I have 2- 64GB fast ones and 6- 128GB slow ones. What resolution, frame rate and REDCODE are we shooting today?"
People will expect our SSDs to work with all RED cameras...
Jim
