Jesse Korosi
- Jul 30, 2009
- Los Angeles, CA
- www.jessekorosi.com
Hi All,
I am looking to find a quick way to Q.C rendered DPX files.
This is what I have tested:
- Render out ProRes dailies with TC and Reel Name columns Q.C'd to ensure they are there and are accurate
- Create a quick edit
- Export an EDL and also a quicktime reference file.
- Import that EDL into RedcineX 351, render out new DPX files
- Import the EDL into FCP and attempt to reconnect to the DPX files.
I would then like to overlay the quicktime reference video on track2 above my EDL reconnected to my DPX frames. Make the opacity on the reference file 50% and I would then be able to just scrub across my timeline to q.c. that all appropriate frames have indeed been rendered.
The Problem:
I am using Glue tools to be able to import DPX sequences as QT wrapped files into FCP. Therefor I can not batch import these files, nor can they be reconnected to an EDL created from the dailies I made...(or at least I dont think they can be based on this test?)
Is there any way to do this in FCP? Or some other software? This could also maybe work in Color....but I am not sure if there is a way to blend 2 layers over top of each other to make this work?
Either way the goal is to simply be able to check the DPX files to ensure that RedcineX has indeed rendered what it should have.
If anyone has any advice that would be greatly appreciated.
Thanks in advance.
The Problem:
Thanks in advance.
