Lens Red One on Rec Scarlet
Mick Doll
Active member
Hi,
excuse me for my bad english for beginning, after i want know if we can to use the Red One's lens on the Red Scarlet and if it's the same for the different accessories.
all the best
And there's a reason for only on the S35 version ?
Do you know when the Scarlett will be available ?
Because the Scarlett Fixed, well its Fixed, hehe, so you can't change and or mount any other lenses,
and the Scarlett 2/3 is a different mount then Standard PL Mount, as the Red One , Epic, and Scarlett S35.
As it has ben said, Scarlett will be out shortly after Epic,
at this point slimmer chance to be out by the end of the year, if not very early next year.
Ok! ;) so if i want change the lens, i'll have to buy the 2/3 Cinema, S35 or FF35 and not the 2/3 standard.
I hope what it's good at the early of 2011 !!!
I thought that there was a PL mount for the 2/3 interchangeable. So all those 16mm PL lenses can be used.
I'm fairly certain there is but we will know for sure when it is closer to release time, but I can't imagine why they wouldn't unless they couldn't.
You can use PL mount lenses on all cameras but the Fixed 2/3.
Correct PL mount on 2/3 Scarlet as well, with windowed, but you can also use fantastic lenses such as the Arri Digi Primes.
My understanding is that the epic, then,the fixed lens scarlet will come out ... followed by other scarlets. We may be talking summer or fall time for the S35. In general, the S35 scarlet camera will have fantastic capabilities and will be the 'B' camera of choice on big productions and the 'A' camera of choice for us little guys! I might pick up an F3 in the mean time ... did that with the EX3 while waiting for scarlet as I do not assume anything on RED releases.
