Redcine-X Build 351 XML Glitch
Julio Quintana
Austin, TX
www.juliomquintana.com
Hey guys. I already emailed Jonathan B. about this, but just thought I would post here in case anyone else runs into it. We edited a music video using the M camera proxies and exported an XML. We then imported it into a Redcine-X timeline (which is freaking awesome, especially with the Red Rocket). We did our color correction, then exported the whole timeline as a long 1080p ProRes HQ file. When we brought it back into FCP to sync it up with the sound, the new color corrected clip was actually longer than the original edit that we exported out of FCP. We thought at first it was a frame rate issue, but both the original FCP project and the Redcine project are 23.98.*When we looked closely we found that every shot in the entire project had been extended by exactly one frame. As in Redcine added one frame to every shot in the project, throwing everything out of sync.
It was only a five minute video, so it was just easier to manually remove the extra frames, but I'd like to know if I'm doing something wrong for future reference.
Julio
Hi Julio,
Just out of curiousity, did you import and export the xml directly into redcine-x or did you use clipfinder or the LUA script
Tunji
Hi Julio,
Tunji
I exported the XML straight from FCP and imported it right into Redcine-X. It really is an awesome workflow if you have a Red Rocket. I'm glad to hear the glitch has already been addressed.
Yes, found and posted that in the other post introducing the build. Glad I wasn't going crazy. :-)
I'm having a problem with creating new QT wrappers. The files are generated but they are just a green screen for the duration of the clip. exporting a QT file (Pro Res) file seems to be OK.
ok the problem seems to have gone away now - after I installed the latest OSX update which involves a restart anyway.
i spoke too soon ! very weird but the next clip I tried to re-wrap gave me the green frames again
wrappers are generated perfectly in 348 - is it a REDcolor2/REDgamma2 issue?
thanks, I didn't look there but it's good to know. Strange that with a computer restart the wrappers did output ok the first time. Anyway, I'm sure it will be resolved soon
Julio
I have a workaround for that. http://www.esperimentocinema.com/journal/2010/11/22/rcx-edl-workflow.html
