Will EPIC 5k Cover the 50-150 Red ZOOM?
julian-nüesch
NEW YORK CITY
Will EPIC 5k Cover the 50-150 Red ZOOM? and what about the 18-50 red Zoom???
i m not talking about the new 17-50 pro zoom.
This is all just conjecture on my part, but here is what I think:
No one has a concrete say on this one way or the other. If there was a published image circle for those lenses, then it would be easy to figure out. However, since the Pro 17-50 covers the Epic when zoomed to 19mm ( http://reduser.net/forum/showthread.php?t=47333 ) and it was designed to cover S35, and the 18-50 was designed to cover S35, my guess would be that it will cover the Epic when zoomed to 19mm as well. (But you may need to go to 20mm.) I would be less concerned about the 50 - 150 as at those focal lengths the image circle usually gets pretty big on most lenses.
I only know that jim said that the 18-85 !!! will work if you zoom in till 22, but because of th bigger sensor your view!! is the same as on R1 in 4K a 18 will do!
So maybe the 18 50 will be oke when you zoom in untill 22mm ?!
I think the 50-150 will be no problem, its a long zoomlens!
R1 1265MX....waiting for Epic.
If anyone wants to arrange to bring one over to me, I can throw it up on our lens projector and tell you in 5 seconds if it will cover.
Or, find some idiot with a 5D outfitted with PL mount. 5D is a larger sensor area.
Well, that will just tell you that it doesn't cover the vastly larger 5D sensor, but it won't let you know if it covers the incrementally larger 5K EPIC image area.
