dreamcolor again
hi,
what do you think about this article i ve found on creativecow and how to get 10 bit through one single SDI input(spec for the HDP2?) for coversion to HDMI 1.3a 10bit RGB prog 444. I 've a kona 3 and my suggestion was to pipe a duallink signal from my kona to the hi5 3g? I'm asking this question because of advises in this forum leading to the hi5 3g for kona3 with dreamcolor? the example below goes with the kona lhi not the kona3 ?!...
PLEASE read below....
"Why do you suggest the HDP2? Wouldn't the AJA Hi5 3G converter be the better choice for me? Since the HP needs a HDMI 1.3 or DisplayPort input to go into DeepColor mode, seems to me that would be the way to go, no?"
No. You can search this forum and read other posts on the topic (I have a DreamColor as well) but the HDP2 provides HDMI 1.3a (via a user supplied and inexpensive DVI to HDMI cable) and it also takes whatever signal you are feeding it and makes it true p. So that would allow you HD and SD capability out of the same Kona when working in 1080p(sf) and using the DreamColor. It also allows SD monitoring on the DreamColor. The hi5 3G simply passes through what it's sent and doesn't output true p, effectively disabling accurate color monitoring on the DreamColor.
You will see other posts that the LHi is enough, and in some cases it is, but to me the HDP2 is kind of a no brainer when working in mixed format environments and using a DreamColor monitor. The combo of the Kona LHi, the DreamColor, the HDP2 is still more cost effective than buying 1 of the other HDSDI 10-bit display panels out there. It's still a good deal and a very nice monitor (in my opinion). It won't do 1080p60, but knowing AJA's abilities I am sure a 3G version of the HDP will fix that at some point.
thank you!
greets
L
Currently no chance. The citation is correct.
You have to make sure that the Dreamcolor is fed true progressive, NOT progressive segmented frames (which most devices do).
hey,
.... what do you mean with no chance? no 10 bit 4:4:4 with the kona 3 and the dreamcolor...?
thx again :) ...
Maybe with future firmware… Ask AJA!
