- Banned
- #1
Matthew Rogers
Banned
- Mar 9, 2007
- Age
- 44
- www.macvilleproductions.com
Hey gang, I am currently working on a feature where we are syncing timecode straight from a SoundDevices 788T straight into two MX red's via a lemo cable (xlr to lemo.) We did a test today when we got a minute because when we would jam the two cameras and the slate from the mixer, the slate would always be a second ahead of the two reds. However, the audio guy said he's always had a problem with the RED's being a second behind, where as I had never seen that before. To make matters worse, when we recorded the slate running and then pulled it into RCX, on one clip the timecode on the slate was 6 frames different compared to 1 frame in the next clip (same camera.) I am really scratching my head on that one because when we shot the first clip, we were actually wired into the the mixer. Do you still have to hit record to sync timecode?
The mixer says he's set at 23.976, so 29.97 shouldn't be an issue.
Not sure what to do since it's so freakin messed up. Would love any advice on what might be wrong. It would be very nice for post if things lined up correctly.
Matthew
Matthew
