Gunleik Groven
REDuser Sponsor
Done and thanks
Cheers
G
Cheers
G
I'm trying to use build 340 in stereo with a Red Rocket but having no luck.
My goal is to view the 3D on my Sony Bravia 3D via HDMI in Side by Side or interleaved if I can.
I can get a 2D image no problem but if I bring in a 3D clip, the monitor just goes black. If I stop Rocket monitor playback I can see it on the computer monitor no problem, but I need it to be on the Bravia to be any use.
Rocket is set to 1920x1080 @ 25FPS, DVI-HDMI. Another thing is it will only output this if I have PSF enabled, but the manual says this only affects HD-SDI so not really sure what's happening.
Rocket firmware 1.1.8.6xx
Any advice?
Jim
For 3d clips, you have to go out the graphics card to the 3d monitor. I usually put the 3D monitor as the second monitor and the maximize the rcx viewer on the 3d monitor.
Just to clarify, RCX does not have to be in the Application folder to install REDline. You don't need to be localadmin, either (just install to a folder you have permissions to). Also, the installer does not do a copy, it creates a symbolic link to the REDline executable inside the REDCINE-X.app bundle.
To manually install REDline to a folder that's in your path, like /home/bin, enter the following from the command line (assuming REDCINE-X.app is in /path/to):
ln -s /path/to/REDCINE-X.app/Contents/MacOS/REDline /home/bin
Alternatively, you can add /path/to/REDCINE-X.app/Contents/MacOS to your path.
So how do I install redline exactly, do I do this from within RCX in the menu option to "Install Redline?"
For clarification, Redline is included in the RCX package contents, correct? Or do I need to obtain a manual download of Redline someplace else?
