Keith Putnam
- Jul 17, 2008
- Rego Park, NY
- isota.blogspot.com
Hi, all.
I'm currently teching a RED feature being shot in the Wasatch Mountains, mostly between 6,500 and 9,000 feet elevation. When we originally checked out all of our gear we decided not to bring any IR cut filters or IR/ND combos, because up until now I've felt that the MX chip is sufficiently less sensitive to IR than the M chip was and, as such, IR cut hasn't been necessary.
However, once we began shooting at altitude the DP and I definitely began noticing a warmish magenta color cast once we stacked ND starting around a 1.2 + .3 and it would get very strong if we went to a 1.2 +.6. As an extreme example we stacked a 1.2 + .9 and got this:
Now, obviously, ND 1.2 + .9 is kind of absurdly dense. But it illustrates the issue.
So, my question is this: does elevation significantly affect IR pollution on the MX chip? I can see it being totally possible that with less atmosphere to filter out IR that more of it is getting through the lens. At sea level the MX seems significanly more resistant to IR to the point where I haven't felt an IR filter was necessary for even an ND 1.2 + .6 stack, but up here in the mountains we seem to start seeing IR pollution with a 1.2 + .3 stack.
Thoughts?
Thoughts?
