Apple Color doesn't correctly render a clip with Keyframes.
Luis Ortiz
NJ-Serial#1321
I color graded a music video, using Apple Color v 1.0.4, and one of the clips doesn't hold it's keyframes when rendering. When I play it back in Color, the clip shows correctly, but when I render it, the vignette in the clip doesn't track with the keyframes. I've tried rendering to 422HQ and DPX with same results. I've even tried trashing the preference file and still no solution.
Has anyone ever had this issue when using Color? If so, does anyone know any workarounds?
Currently using:
Model Name: Mac Pro
Model Identifier: MacPro2,1
Processor Name: Quad-Core Intel Xeon
Processor Speed: 3 GHz
Number Of Processors: 2
Total Number Of Cores: 8
L2 Cache (per processor): 8 MB
Memory: 8 GB
Bus Speed: 1.33 GHz
Boot ROM Version: MP21.007F.B08
SMC Version (system): 1.15f3
ATI Radeon X1900 XT:
Chipset Model: ATY,RadeonX1900
Type: Display
Bus: PCIe
Slot: Slot-1
PCIe Lane Width: x16
VRAM (Total): 512 MB
Vendor: ATI (0x1002)
Device ID: 0x7249
Revision ID: 0x0000
ROM Revision: 113-A52027-202
EFI Driver Version: 01.00.202
Displays:
Cinema HD:
Resolution: 1920 x 1200
Depth: 32-Bit Color
Core Image: Hardware Accelerated
Main Display: Yes
Mirror: Off
Online: Yes
Quartz Extreme: Supported
Rotation: Supported
Matrox MXO:
Resolution: 1920 x 1200 @ 60 Hz
Depth: 32-Bit Color
Mirror: Off
Online: Yes
Rotation: Supported
See photos of this issue.
Unfortunately Color, especially the older version, is very buggy.
Have you tried deleting the keyframes and adding them again?
Deleted all the keyframes and added new ones. Still doesn't work. Thanks for your help, though.
