Michael.Romanyshyn
- Oct 5, 2010
Hello all,
First post here. I apologize if this has been addressed, but I could not find any threads in any forum relating to multi camera editing with a Red workflow.
It has been decided by my clients to shoot an event with 16 cameras, half of them Red at 4K at 23.98fps, the other half will be captured to tape (HDCAM). I have experience editing multi camera projects and have come to like standard definition down-converts the best. It provides decent quality viewing and works effortlessly on my machine.
My question is about which is the best way to down-convert. Using Redrushes, I am doing a test right now with the following settings.
Debayer quality is set to Half Res (standard)
Resizing to 640x480
Outputting as QT using ProRes 422 codec (since I don't see DVCPRO50 or NTSC as an option).
The other half of the cameras will be ingested using ProRes 422 as well, even though I like DVCPro/NTSC the best.
1. Would it make sense to convert the raw footage as described above, then make conversions to DVCPRO/NTSC using compressor? Is there a faster or better way to utilize Redrushes (don't know if Redrocket card is in the budget)?
2. Would it make better sense to use the 640x480 ProRes conversions and import the HDCAM tapes to the same size and same codec? My system would handle 16 ProRes angles in FCP, though there would be some choking as the sequence gets cut to shreds.
A third question relates to transfer of media from Red drives to external drives. Is there any additional software needed for my macbook pro to see these drives? Can I daisy chain a Red Drive onto a G-tech external drive?
Just want to make sure there are no unforeseen circumstances.
Thanks in advance for any input, suggestions, etc,
Mike
Resizing to 640x480
Mike
