Avid Metafuze Question
Philliperry
New member
How do you change the format, i.e from DNX185 to DNX40, on all of the files (once you've opened them in Metafuze) instead of one by one?
select one, stand on the format column, change it from 10bit to the appropriate
1080 (fps)P go to the list on the right, stand on format, hit enter. All your files should have accepted the change. Then on the transcode it will change accordingly to DNxHD 36/40.
Hope it helps. try once twice ..... 13 times before you give up. It works.
