Stephen Williams
It was nothing special to see anyway.
Alexa & Epic were shown.
Contrary to most people's perceptions, high volume manufacturing does not necessarily yield inferior quality.
There is one critical difference with a Red Pro Prime versus a Master Prime however, The RPP is designed to work with the Mysterium sensor, where the critical plane of focus for RG and B components of the light are hitting a single plane. The Master Prime has to hit those corresponding RGB planes as they occur on film, in emulsion layers of CYM, so they are in fact hitting focusing at three critical planes. Maybe this is a minor concession, but as the sensors begin increasing in resolution, you will see the Master Prime quality begin to deteriorate while the RPP quality will hold up.
For real? That translates to nearly 300 megapixels of potential resolution on a Super35mm sensor. And yet I believe it. Talk about future proof!
If the lens is computed for the OLPF and sensor cover glass then their effect is known, if the lens was not computed for anything but air between the back of the lens and the focal plane, then you can expect some degradation of the image, how much depends on the lens and the f/ stop etc used and the size of the pixel, and thinkness and type of glass used in the "plates".
You can also get f/ stop dependent focus shift in lenses that are not corrected for the plates since the "best focus" can become a little off from the negative spherical aberration etc.
Another matter is if a lens can focus a spot smaller than one pixel (four pixel group in a Bayer sensor), and the OLPF does not block all that fine detail from getting to the sensor the moire issues can increase for a given setting of the OLPF comp and such.
yep, for real. I tested 14mm, 35mm and 75mm on an Arri MTF machine with all of them peaking between f/4 and f/4.5 with the 14mm beeing the sharpest of them all.
The OLPF aberrations would be known in the case of the RPP of course. And like you point out Dan, no Master Prime or any other lens that doesn't take these factors into account can't expect to out-perform a lens that is designed to match the sensor across all f-stops. Well put.
...but as the sensors begin increasing in resolution, you will see the Master Prime quality begin to deteriorate while the RPP quality will hold up.
again, please show how.
Sure, RPPs are good value for money and we love them, no doubt about that, but I think it makes a lot of damage to this forum to make statements like yours.
To my modest experience shooting both, MPs have significantly higher contrast, significantly higher MTF, significantly less distortion, significantly more even, flatter illumination, less flare, less ghosting, less comma and are in every single way better than RPPs. I tested on MTF machine, on R1, on Canon DSLR and on a lens projector at ARRI facility in Sydney. I shot Red Primes too, with the same camera in the same place. You can clearly see the difference between them when inter-cutting the shots and the only thing I can confirm is the opposite to what you are saying.
Basically the theory is:
Jeff, not sure why it is well put. Do you have any examples/tests/anything to suggest the above statement has any merit at all? All the experience I had shooting RPPs and MPs indicates the opposite to be true.
Have you shot with both RPPs and MPs and compared the two or are you shooting from the hip? :sneaky2:
Sorry, missed this one. Obviously I was "shooting from hip" because I didn't have a series of charts to prove or explain every nuance of what I was trying to communicate. Of course I can't prove it. That's the entire point. I've seen how ruffled everyone's feathers gets when someone even mentions that maybe Master Primes were not divinely hewn by the right hand of God. LOL!
But in all seriousness, I like and respect you and your work, Pawel. I'll take your counterpoint like a Man!![]()
That's the point isn't it? I wouldn't suggest that the MP's are 'deteriorating' in image quality beyond a certain resolution digital sensor unless you've got pictures...
I think he means personal experience
The OLPF aberrations would be known in the case of the RPP of course. .
