Color Looping Bug with Canon 5D footage
Michael Dwass
I have a Color project that is a mix of Red camera footage and Canon 5D (transcoded to Prores4444). I am experiencing frozen images on some of the Canon footage. I ran Clipfinder's Looping Bug fix with no effect. What is causing this? I have been able to load the individual shots into a new Color project and they are fine. Thanks for your help.
Michael
are you keep your r3d native in color? color really doesn't like mixed timelines at all, that may be the cause of your problems. I'd try (a small test first) use clipfinder to reconnect to all you r3d, send all that to cine x, tweak everything as you need to, do a full debayer to proress 4x4, and use clipfinder to reconnect to those QT files, re conform the XML and put that through color.
Yes, the Red files are native wrapped r3d (log and transferred). They are mixed with the Prores4444.
Michael
again, color hates mixed timelines, you may be rendere down to 4x4 in the timeline, but you connect to the r3d files when u go to color. i'd re conform everything so it all matches.
