Is cineX debayer different to cs5 debayer?
J Davis
NYC
Just wondering if the debayer from CS5 pp or ae is as good as cine X
I know the BIG RESOLUTION NEWS thread is old but it points out that Graeme's debayer techniques yield higher than expected results
...that 4.5K from the same sensor and lens yields a true 4.1K measured resolution.
http://www.reduser.net/forum/showthread.php?t=41121
My understanding of the CS5 debayer is that it uses adobe's algorithm? Is that correct? Is it inferior to Graeme's?
What if CS5 was used in conjunction with a rocket card. Would that mean Graeme's debayer algorithm is used instead?
It's all through the SDK and the same.
Graeme
How does FCP's Log and Transfer debayering work?
Although you have no control over how it debayers and creates your ProRes file, does it use your (red's) full debayering method on best?
