Emin Mahrt
New member
- Jul 20, 2010
Hi Reduser,
for sure im not the only one having problems with the 4K res of the raw red files. Its impossible to work with it if you work on a personal computer (like me, iMac 3ghz, 4gb ram)
Until now i war working with QT on 1920x1080 with apple pro res 422. The problem is - i lost all my qt in reason of a hdd crash. Now i need to code all my red raw files back to QTs -> with a iMac...
Im having about 60 hours of raw material. One sec encoding to QT 1920x1080 with h264 OR even no codec takes about one min.
1 sek --encoding--> 1 min
Is there any way (except of a red rocket) to make this faster? Any Codec, or a different solution. I just need files i can work with so the director can do the raw master cutting by himself and the sound technician can add the external sound to the clips in final cut.
Thank you for your help and best regards
Emin
Emin
