Mark Pugh
AJA Hi5 HD-SDI to HDMI Converters (3 units available) $350 each OBO
AJA Ha5 HDMI to HD-SDI Converters (2 units available) $320 each OBO
All are AS NEW, UNUSED.
AJA DWP Power supplies included (usually they purchased separately at extra cost)
Also available, GEFEN HD Personal Video Recorder. $500
Also AS NEW, UNUSED.
When combined with the the AJA converters, provides an inexpensive playback solution on set.
The HA5 HDMI to SD/HD-SDI Video and Audio Converter from Aja converts (1) HDMI signal to SD- or HD-SDI output and is capable of embedding up to (8) channels of HDMI audio into the output signal for a single-cable audio-video connection. It features (2) SD/HD-SDI outputs. This unit equalizes the input signal to support extended HDMI cable runs of up to 131'. PLL clock filtering is included to produce low jitter on output signals. LED lights provide a visual indicator of line status. It does not support HDCP content, meaning copyright-protected media may not display correctly with this device.
HDMI to SD/HD-SDI Conversion
This unit converts (1) HDMI input to SD- or HD-SDI on (2) outputs.
Audio
HDMI audio is embedded into the SD/HD-SDI output.
Transmission Distances
All signals are equalized and the unit supports cable runs of up to 131'.
The Hi5 HD-SDI/SDI to HDMI Video and Audio Converter from AJA is a device designed to convert SDI or HD-SDI signals to HDMI for driving HDMI monitors. This unit also supports embedded SD/HD-SDI audio in the HDMI output, allowing for a convenient single-cable, audio-video connection. The Hi5 provides 2-channel, RCA-style, audio outputs for the separate monitoring of audio feeds. It also offers a looping SDI/HD-SDI output, which is useful for connecting additional equipment or to achieve a daisy-chain configuration with multiple monitors running from the same SDI/HD-SDI source.
HD-SDI/SDI to HDMI Conversion
This unit is designed to convert SDI or HD-SDI signals to HDMI for driving HDMI monitors.
Embedded Audio Support
This unit supports embedded SD/HD-SDI audio in the HDMI output, as well, allowing for a convenient single-cable, audio-video connection.
Separate Audio Monitoring
The Hi5 has 2-channel, RCA-style, audio outputs for the separate monitoring of audio feeds if necessary.
Connect Additional Equipment
This device offers a looping SDI/HD-SDI output, which is useful for connecting additional equipment or to achieve a daisy-chain configuration with multiple monitors.
Audio
