roryhinds
- Jan 15, 2007
- Vancouver, BC, Canada
- www.minefilms.com
I'm trying to figure out which is the best tool for achieve calibration on a Panasonic Plasma then at a later date on a JVC Projector.
I'm unclear as to what CalMAN does as it seems to just take measurements and you have to manually correct your display using the displays built in menu controls.
Cine-Tal's Cinespace looks confusing as I'm unsure what applications I need... is it just the CineProfiler or do I need equalEyes too?
I'm not needing my computers OS to be corrected at this stage and only want to get the Plasma to be calibrate, so can CineProfiler work with the X-rite Hubble and calibrate the Plasma? Will it create the 3D LUT which can be loaded on the the HDLink Pro 3D?
There is also LightSpace CMS.
Could anyone give advice on what calibration software will be able to calibrate a Panasonic Plasma to Rec709 and P3 (as close to P3 as the Plasma allows)
I'm going to be going...
HDSDI out
into a HDLinkPro 3D
DisplayPort to HDMI adaptor to get HDMI 10bit RGB out
into the HDMI of the Panasonic Plasma
I'll have a X-Rite Hubble as the probe although already own the i1Pro but have heard the Hubble is more precise.
I'm on a Mac but can run Bootcamp if Windows is need.
Will be using Smoke on Mac, Resolve (when its released) FCP, Color and want to be able to color correct using the Panasonic Plasma then in a few years move up to the JVC projector.
HDSDI out
into a HDLinkPro 3D
