Marco Materassi
Active member
- Jul 1, 2010
Hello, I'm very new to this software and I need to figure out a problem.
I have and EDL of a very simple project from premiere cs5. The EDL contains only video data (no audio layers). IN the EDL I have 3 clips, each one with it's own specific TC in and OUT. When I conform (it finds the right clips with no problem) and I build the construct, it displays me all the clips in all their lenght. Basically in the construct I see the clips with the duration of the file and not of the clip in the edl. The project and clips and edl are all 24fps. If I want the right duration of each clip I have to go to the editor menu and cut manually each clip, and that sucks. I think I'm doing something wrong....
EXAMPLE: In the EDL I have one clip which is:
source in IN 21:21:29:09
source Out: 21:21:33:06
record in 11:03
record out : 15:00
So in premiere this clip last for almost 4 seconds.
In the construct instead I see the whole file....any solutions? I tried with different EDLs but same result.
record in 11:03
record out : 15:00
