Andrew Patterson
- Sep 13, 2009
I'm needing to buy all the necessary filters for outdoor shooting. I understand that I need several ND Filters (.3 and .6 and 1.2 are what I intend to buy).
My questions regard the Infrared Filters versus Non-Infrared Filters. If I buy one Infrared Filter or one Hot Mirror Filter and put it in the front (furthest away from the lens), will that take care of all of my IR problems?
Or would it be better to buy each ND with the Hot Mirror and IR built in? If that's the case, can I stack IRND Hot Mirror Filters.
I've read that IR doesn't matter below .9 -- if that's the case can my .3 ND and my .6 ND be non-IR and non Hot Mirror? And if that's the case, can my 1.2 be an IRND Hot Mirror and always be in front of the .6 for POLA?
To sum up, I have been looking for the perfect combination but don't understand the stacking. I'd like to spend less than $3000, but will go over for the best results.
Thank you all for the continued guidance for the younger and less experienced!
Andrew
Andrew
