How to push Record from RS422 with C-Motion
42
Tbilisi , Georgia
sarke.ge
Good day .
I own C-Motion FF , and it is connected to RS422 on my camera .
When i try to run camera from C-Motion , camera going to PlayBack Mode .
Did i need to change any settings in my camera , or i need to change signal type in my FF ?
GPI settings are on Record .
Thanks.
Not sure about the RS422 connector, but im pretty sure the GPIO settings are just affecting the rear AUX connectors. Best you send an email to cmotion, I´m sure Christian can help you out.
Manuel
The function of the AUX port is hardwired. Pin 5 starts/stops recording, and pin 7 plays back last clip. Seems like your cable has switched the pins.
The cmotion cable RRR-1 to start/stopp the camera at the 10p Lemo connector has the following pins:
Pin 5: Record
Pin 7: Playback
Button RUN at the cmotion hand unit (coperate or cvolution) controls "Record" and button MARKER controls "Playback"
Please also check the camera setting in the following camera menu:
SETUP>PREFERENCES>GPIO
Please check if input A or input B is set to "RECORD".
BR
Martin
