Jesse Korosi
- Jul 30, 2009
- Los Angeles, CA
- www.jessekorosi.com
I have recently switched over from using an LTO 3 A Series deck creating Master Backups for clients and am now using an LTO4 deck, which I guess is not called an "A-Series".
Several people had directed me towards the regular LTO4 deck and BRU software as a better alternative then the A-Series LTO3. I guess my main question is, why is the LTO4 regular series the "Industry Standard" and what makes it better then the A-Series? From the few months I have been using the LTO4, it seems to have a lot of draw backs from the A-Series deck I was using before such as:
- Your tape could be opened simply through Safari, with the correct log in information assigned. Therefor you wouldn't need BRU or any other software to view or send something to the tape.
- Looking at what was on your tape was as simple as looking at what is on an external hard drive. (no archive or definition needed to be loaded)
- If an archive has been lost it is much more painful to find out what is on the tape. I have been shown the process through terminal, but comparing this to just popping the tape in is pretty painful.
- When I used to back up anything to my LTO3-A-Series, technically all I needed was the tape. Now I need paperwork to go along with it that states the Archive ID, Buffer Size etc.. and also a disc or usb key that will hold the actual Archive folder.
- And then once I deliver a tape with all of the paperwork and disc and or usb key I then have to (or at least should in my best interest) keep all of that on file in my office.... Versus just sending them the tape and if they ever came back all I would need is the tape.
- I guess there is something nice also about just being able to actually open up something to actually view what it within your tape. Not what an archived text file says is on your tape.
I am sure I am missing something or maybe it is as simple as the LTO4 is more stable? Either way any information would be greatly appreciated.
Thanks in advance,
Thanks in advance,
