NUKE- color space-workflow to grade color ?
kito
maroc-casablanca
www.youtube.com
Hello..
just straight forward...we just had RED materials and I just coming with some questions, what is the main principals for color grading inside NUKE ? and later on the Output will deliver into cinema ?
we're using Nuke v.6.0.7
1. What is the colorspace base--> lin,REDspace,cineon ?
2. whut the things we should aware instead colorspace and for final output ?
we have limited post facility and we just doing for Short film--as a test. only FCP and nuke.
thanks and cheers
kito
Hello..
thanks and cheers
kito
Nuke is still using the old color science (and I can't figure out why they haven't updated the read node to reflect the new color science...) - grading is best handled in Nuke by following a input node up with a grade node, transform node, and then a reformat node.
The color space depends on whether you are doing any comp work or this is a final pass. Lin for comps, redspace with a 2.2 gamma for final passes (unless you are doing work destined for film then go to Cineon space I believe).
Also try out the Truelight node at the end of things and play around with that - especially if you are going for a feature look. DPX files for the output.
THANX A LOT, Andrew. I really appreciate your respon.
Yeah here..we re using Lin for comps.
again ...thank u very much:thumbsup::thumbsup:
