Maya_Kazan
New member
- Jul 13, 2010
Hi there,
I'm new to the RED, and working on a short that has absolutely no money for post, so post-houses aren't in the cards for me.
I'm at the end of my workflow, and I can't figure out how to finish.
Here is the workflow to date:
I made 422 quicktimes in Redcine-x to edit. When I was done editing, I replaced all shots that had been altered in terms of motion, etc. with 4444 quicktimes. Then I conformed using Clipfinder to the _H proxies, made an xml, sent that xml to FCP, and sent the sequence to Color.
Color flipped out- kept crashing, and then wouldn't reopen the project, and then started rendering our footage into these crazy images that were basically pink and green static. I was willing to put up with that, sort of, except-- THE METADATA WAS MISSING. The metadata did not apply to the r3ds in Color. I had been under the impression that it would connect to the metadata automatically. However, I understand that the camera proxies do not have the metadata attached/burned-in, and that is probably why the metadata did not come into Color. But I don't know how to fix the problem. Everything I was reading said that the _H proxies were a fine way to go, and that Color would automatically connect to the r3ds (presumably, with their metadata...)
What should I do? Is there a different way to conform, to r3ds that have the metadata burned in? I really want to start the CC with the image as I shot it on set, not with the RAW image. What is the easiest way to bring the metadata into color?
I tried to go into Redcine-x and export a REDCODE file from the clip that I had applied the 'meta' setting to--- and it made a "REDC, Linear PCM, Timecode" file. It comes up gray, it is tiny, it will not connect to my sequence in FCP.
RedAlert will render a Redcode file-- but I can't get the metadata to attach. It doesn't load my metadata correctly- I can match it by hand to the settings that come up (correctly) in Redcine-x, but RedAlert seems to be missing a setting for "FLUT Control," so I can't get it right.
What is the best way to go about fixing this problem? Is there a way to burn in metadata so that my conformed timeline will carry that information to Color? Should Color be reading that information from somewhere else?
I'm working on a laptop, which means everything is taking FOREVER, so I can't afford to do the 'trial and error' method any longer.
Any suggestions would be greatly appreciated!!!
Thank you!
Maya
Thank you!
Maya
