clipfinder 2.5beta3 doesn't process .rsx
Sebastian Gross
Berlin, Germany
www.piratesnparadise.de
hey there,
-clipfinder 2.5beta3
-red alert version (21.0.0.)
-redcine-x 256
i tried to batch render a few .r3d to 1280x720 (lanczos).mov
like i did many times before, but CF 2.5beta3 just doesn't seem to
process the .rsx-information.
did the workaround with redcine-x - no problems with the exact same files.
any ideas what might cause this? or did i not see some footnote warning me about this issue?
s.
Just as a heads up REDALERT DOES NOT support Color science past build 21. So footage captured on BUILD 30 will never look correct.
David
Sebastian,
I just tried rendering with Clipfinder and Redline 256 and my RSX data gets rendered. You do have look source "RSX File" selected in the render window correct?
What RSX changes are not coming through?
Where did you modify the RSX file? Clipfinder, RCx, etc..
Dusty
i made the changes in redalert.
"look source" is activated, just as usual.
as i wrote, the created .rsx gets processed by redcine but not by clipfinder,
there is no specific thing not coming through, it seems just as if clipfinder doesn't notice the .rsx file at all.
i deleted it, re-created it, copied it - nothing.
s.
