RedRocket with Matrox CompressHD H.264 Accelerator Card ?
Etienne Caron
I would like to know if RedRocket could be combine with Matrox CompressHD H.264 Accelerator Card ?
Just want to generate fastest H.264 encoding for BlueRay creation.
regards.
It works fine for me. I got the RR and the MXO2 pcie card installed.
you should be able to use Max technology when you choose Max H.264 codec in the QT setting when you export from REDCINE-X. REDCINE-X with RR with decode/debayer R3D in realtime, then MAX will take care of encoding to H.264 quite fast (usually about over 2 times faster than 8 core Mac Pro without Max).
Thanks everyone. will test both card together.
Sorry, but i got black frame when i choose to export from redcine X (256) via the Matox H.264. Normal H.264 work fine.
I'm using the last firmware: Matrox_CompressHD_version_1.9.1.dmg
regards
